Old 09-15-2008, 06:26 PM   #1 (permalink)
405dentech's Avatar
Default Which rack and pinion
I'm building a 2 seater short sand car and was wondering which rack and pinion you guys would recommend. I ordered a 14inch buggy rack from Dan's Performance and it just looks extremely small and weak so i'm sending it back.
405dentech is offline   Reply With Quote
Old 09-15-2008, 07:02 PM   #2 (permalink)
Administrator
K-fab's Avatar
Default Re: Which rack and pinion
Do you need a center steer rack or do you need a rack that the tie rods attach to out on the ends?
If you need a center steer rack, I have a Howe unit that I'll let go. It has about 100 miles or so on it.
Old 09-15-2008, 07:10 PM   #3 (permalink)
405dentech's Avatar
I really don't know which rack i need. I was thinking about one where i could use heim joints instead of tie rod ends. How do i tell which rack i need?
Old 09-15-2008, 07:12 PM   #4 (permalink)
405dentech's Avatar
The center steer units seem like they would be quite a bit stronger but i'm not sure.
Old 09-15-2008, 07:52 PM   #5 (permalink)
Administrator
K-fab's Avatar
As a general rule*, rack spacing depends on the suspension setup.
If your front a-arms front mounts are close together at the nose of the car, then you need the spacing like on the rack in the pic.
If your a-arms are on each side of the car and don't come anywhere near each other (think quad front end), then you need a wide mount setup.
* yea, yea, it's a blanket statement!
Old 09-15-2008, 08:37 PM   #6 (permalink)
405dentech's Avatar
My front lower a arm front mounts are about 19 inches apart.
Old 09-15-2008, 09:07 PM   #7 (permalink)
Administrator
K-fab's Avatar
Ah, then my Howe won't work for you. Sorry.
Old 09-15-2008, 09:28 PM   #8 (permalink)
405dentech's Avatar
Thank you for your K-FAB.
Old 09-15-2008, 11:10 PM   #9 (permalink)
bdkw1's Avatar
19" apart? Boy do I have a rack for you.....
Comes with spare parts.......
Old 09-15-2008, 11:20 PM   #10 (permalink)
405dentech's Avatar
After reading some other posts and looking at the few pictures that i have found. The 14 inch rack that i ordered for my SSC seems to be the one everyone is using.
Stiletto Rack and Pinion Unit flyingpig File Library 0 06-22-2008 08:19 PM
Custom built rack and pinion throttle Controls and electrical 16 03-26-2008 03:42 PM
steering setup minirailguy Suspension - Wheels & Tires 25 03-20-2007 05:05 PM
Manual Rack & Pinion Steering.. Just got mine! Kawabuggy Suspension - Wheels & Tires 7 02-26-2007 04:42 PM
Any body built a buggy with a power rack and pinion? renegadespec1 Controls and electrical 17 01-22-2007 05:27 AM
