I am paralyzed from the arm pits down .I am try to get hand brakes to work on a C-Moore buggy. I have a Pilot steering mounted on a C-Moore buggy with a steering quicker and power steering, so I can get to full steering lock in about 90 degree turn of the steering wheel. I am using Pilot Master cylinders with Wilwood calipers. I do not have enought braking power, I have maybe 40% of what I need. I think I need more flow volume get the calipers to work right. The Pilot master cylinder have a small piston diameter so I get a high line pressure but low volume flow. If go to a master cylinder with large diameter piston, my line pressure will go down but flow volume will up, but I think this will require more brake lever force. Right now I am pulling on the brake lever as hard as I can and have poor brakes. There is litte room between the calipers a the rim, so I do not think I room for bigger calipers. Does anybody have any ideas what I should try ? Does my thinking about bigger diameter pistons sound right ?
#4 (permalink) | |
i'm in the same boat, i had to use a larger master cylinder when my hand controls were built.
i just found THIS it should have no problem pushing enough fluid since its for a road race bike running dual piston, and dual calipers Quote:
#6 (permalink) |
Hi Stress,
Where are you located? I have a hand master cylinder from a Polaris Victory motorcycle (big V-Twin) that I'd be willing to let you try out to see if it helps. /Frank
You know you are blessed when your wife loves you and she understands your need for tools and a shop! Coming Soon www.minibuggysupply.com |
#7 (permalink) |
Smaller piston in the master cylinder makes for a longer pedal/lever throw and higher pressures at the caliper. It's the ratio of surface area from the master cylinder piston to the caliper piston(s).
Larger piston m/c will lessen the throw, but require more force to get the same amount of clamping force a smaller piston m/c can produce at the caliper. If you need more squeeze power at the caliper, you need to go to a smaller piston master cylinder or a four piston caliper instead of a two piston caliper. It has nothing to do with flow or volume - the displacement/movement of fluid is very little/small.
#8 (permalink) |
If a way undersized master cylinder is used, it will never displace the volume of 2 large calipers tho....You still have to push the large pistons out to apply pressure, and displace all the fluid are when it moves.... what is the bore of a pilot master cylinder, 1/2" maybe?
#10 (permalink) |
If your lever is going all the way to the steering wheel you need to get a larger bore master. I have also heard that stainless lines can help firm up your brakes, but I have a hard time believing since you still have rubber lines which have to flex more than steel.
If your lever feels hard, but nothing happens you need to go to a smaller bore master to increase your mechanical advantage. I also like bugpacs idea. My dad did something similar with a 2.8 v6 powered buggy he had. Stock master just gave you foot cramps you had to push it so hard, so he ran a levered push rod to a power master that sat back near the engine. You could do the same thing with a cable or a hydraulic system in between. Firefly's and similar small cars have pretty small vacuum pots that can be hidden fairly well. Grant |
| Yamaha FJ 1200 Carb Problems | DesertDrifter | Motor - Engine | 9 | 12-04-2007 04:12 PM |
| Will M/C Shocks Work For A Mini Buggy? | Kawabuggy | Suspension - Wheels & Tires | 1 | 12-02-2007 12:41 AM |
| Yamaha xj 900 in minirail? Will it work? | randy | Motor - Engine | 3 | 01-31-2007 10:44 PM |
| Minirail + Bad landing = Problems | Sandaholic | MiniBuggy.net Lounge! | 55 | 05-07-2006 01:20 AM |
| Airbrush and paint work..... | yoshi | MiniBuggy.net Lounge! | 19 | 04-04-2006 04:14 PM |
