Old 08-16-2008, 05:46 AM   #1 (permalink)
Default PAIR solenoid on GSXR 600
I am doing my electrical and was wondering if I need to keep the PAIR solenoid in the systems. According to the manual looks like it just injects fresh air from the air box into the head. Can I just put the hoses into a filtered breather? The motor is an 05.
bigtuna is offline   Reply With Quote
Old 08-16-2008, 02:02 PM   #2 (permalink)
masterfabr's Avatar
Default Re: PAIR solenoid on GSXR 600
Do away with everything and plug the holes in the head by tapping for a 6MM ,I think it is, set screw.You won't even have to drill out the holes .Just tap what's there.
Old 08-16-2008, 02:46 PM   #3 (permalink)
Thank you
Old 08-16-2008, 05:38 PM   #4 (permalink)
masterfabr's Avatar
You're welcome but I forgot to mention to not tap the hole all the way through.Just go deep enough to get the set screw approximately flush with the surface.seat the set screw firmly into the partially formed threads so it locks in place.
Pair of 6.75 x 15 STU Smoothees $125obo dlisabeth For Sale 2 07-15-2008 01:05 AM
gsxr 750 dimensions Battleborn Motor - Engine 0 08-27-2007 08:01 AM
ssc w/2002 gsxr 1000 mini buggy man Show off your toys in here! 40 01-31-2007 08:25 PM
GSXR Engine drivetrain, will it last in a buggy minirailguy Driveline 12 01-11-2007 11:45 PM
GSXR 1000 Questions (answers and tricks) al Motor - Engine 15 02-23-2006 04:52 AM
