#42 (permalink) |
The way I wired my rail it doesn't use the frame as a ground. It has a cable that runs back to the battery from the grounding locations.....I use a #2 from the battery to the engine block, a #2 from the battery to a grounding point in the electrical box and then a #10 up to the front of the car for the gauges and switches. Basically everything has its own grounding path back to the battery.
I did it this way because I didnt want to scrap off the powder coating plus it eleminates the potential of a bad ground using your radiator or engine as a path for return. And of course I did check the ground points for proper torque and contact. ![]()
Seems that gas prices have killed peoples desire to do any duning.![]() |
#44 (permalink) |
Ya, I figured I would throw it out there. Some people dont understand wiring or electricity very well so its always nice to help, even if its not relievent(sp?)or on subject.
#45 (permalink) |
Oh I agree completely but I didn't want him to go on a wild goose chase.Grounds are perhaps the biggest issue there is in electrical diagnosis.WHen checking for bad grounds measure the voltage drop in the connection.should be nearly zero.
An open mind is a virtue-----so long as all the common sense has not leaked out! |
#46 (permalink) |
ANd checking a joints resistance(ohms) is nearly useless in electrical diagnosis since there may be 0 ohms but be incapable of carrying even VERY low amps that are useless.
#47 (permalink) |
Busa, your problem sounds exactly like what I went through, but I was putting out approx. 14.7 to 14.8v at r's. I ran an Odyssey, it shorted out. Odyssey gave me a new one after checking it out thoroughly, which in turn shorted out. They wouldn't do the 3 strikes on me, so I got a deep cell motorcycle battery and run it with my lights on which drops the output voltage to about 13.5v.
I tried changing the regulator to no avail. The bad news is that I never found the cause of the high output voltage, but the good news is I've never shorted out another battery...and you can see me coming a mile away ![]()
My Success in Life is measured in how many stories my kids tell that start with " My Dad and I....."
#48 (permalink) |
I believe the proper output voltage for the regualtor unloaded is 14.5-14-8 vdc when reved to around 5000rpm's....Mine I believe is similiar. I think, well hope........ it just a bad battery. We'll soon see.
#49 (permalink) |
what about the amp draw on start up I have seen many cars and trucks kill a battery because of the starter drawing to many amps and shorting out the battery
I don't have any idea what the odysseys will draw just something else to check![]() |
#50 (permalink) |
My uncle had a jeep liberty that just lost a battery. It wouldn't start after stopping for 5 minutes, and he said it showed 12.8 volts, but none with a load. It was the stock battery, so it is not that uncommon, and I am sure that is what happened to you.
| Oregon and Idaho Dunes, 2008 - Post your planned dates | Gene | MiniBuggy.net Lounge! | 12 | 03-14-2008 06:37 PM |
| Oregon dunes trip...MARCH 15-16th??? | busasandrail | Events and Group Gatherings | 26 | 03-12-2008 05:03 PM |
| RR in the dunes | bitsiphon | Ridge Runner | 9 | 09-18-2007 05:17 PM |
| Oregon Dunes - July 21-27 - Coos Bay | DuneMe | MiniBuggy.net Lounge! | 5 | 02-25-2007 05:19 AM |
| Oregon dunes trip | busasandrail | MiniBuggy.net Lounge! | 5 | 05-15-2006 02:09 PM |
