Old 07-19-2008, 11:43 PM   #1 (permalink)
Default yzf600r no spark
hey guys
im putting a yzf600r 2001 in a buggy and have the motor in and have looped the sidestand and clutch switch. it has carbs with original fuel pump. i do not have gas or coolant in yet but does have oil. i was just trying to see if i could get it to turn over. it does turn over but no spark. i cannot find a tipover sensor on the haynes manual. i can scan the diagram and put it up here if anyone wants to help? also i dont have bar controls i just jumped the start and kill switch to get it to turn over. i am going to put a toggle switch and push button start on it. anyone know where to get one of these. i have been looking on the site for awhile now and am very impressed with the talent alot of u guys have building these buggies. i had another buggy with 500ex 1995 engine and was alot simpler than this engine. i have this 600 engine in a two seat china buggy. original motor was a dog. ill put some pics up when im done with the motor and axle swap and beefing the frame up.... thanks for any help
brian, okla city,ok
moon701 is offline   Reply With Quote
Old 07-21-2008, 01:21 PM   #2 (permalink)
Default Re: yzf600r no spark
heres a pic of the project. can anyone help?????? i have heard of a resistor u have to put in because of the antitheft. the wire diagram does not show any antitheft? if anyone has any thoughts let me know
Old 07-21-2008, 01:38 PM   #3 (permalink)
yoshi's Avatar
You prob. need a resistor for the ignition, you can't just use a switch to bypass the original, it has to read a load, at least that's the way it is with a busa. The diagram won't show a resistor because it's built into the stock key ignition....
www.sinistersandsports.com
Old 07-21-2008, 06:49 PM   #4 (permalink)
heres the diagram may be a little hard to read. is it the grey wire that u put the resistor in line with coming off the ignition to the coils. if so does anyone know what ohm resistor it is? also i have ordered the kill switch/start button that actually goes on the bike. im gonna go that route instead of toggle switch. thanks yoshi for the help! u have some sick sandrails!!!
01'Cbr929rr. No spark or fuel. PLEASE HELP! cbr929_build_up Motor - Engine 20 09-20-2007 05:01 AM
no spark Vanet Controls and electrical 9 04-17-2007 04:39 PM
Spark arrestor buggito Motor - Engine 8 03-17-2007 10:05 PM
spark on 929 2001 fuel inj. driller Controls and electrical 3 12-05-2006 03:34 AM
spark arrestor hotwheels000 Motor - Engine 12 03-09-2006 03:08 PM
