Old 12-28-2007, 06:02 PM   #1 (permalink)
edride's Avatar
Default Clutch Pedal Stop
Where can I find a clutch pedal stop to go on a CNC Pedal set up?
Thanks
edride is offline   Reply With Quote
Old 12-28-2007, 06:13 PM   #2 (permalink)
busasandrail's Avatar
Default Re: Clutch Pedal Stop
I made my own out of a 3/16" piece of flat bar.....I have also seen a bolt and jam nut for a stop.
Old 12-28-2007, 07:50 PM   #3 (permalink)
Admin
Gene's Avatar
You can use a longer bolt and two nuts to clamp it in the CNC mount. You may have to add some threads to the bolt since it will probably have too few to get it where it does any good.
Old 01-02-2008, 04:06 AM   #4 (permalink)
HarveyMushman's Avatar
Hi Gene,
I made my own, also for CNC pedal set. *Pretty simple, plus I added a rubber stop. *Here is a pic.
Happy New Year,
Harv
HarveyMushman is offline   Reply With Quote
Old 01-02-2008, 04:11 AM   #5 (permalink)
PS
Are there any threads on cracked busa clutch slave cylinder mount repair or reinforcement (primary sprocket chain guard slave mount). *I cracked mine I think from excess fluid pressure. *The pedal stop may help but I am thinking of adding a simple brace to support the force to the case mounting bolts. *But before I do maybe someone has done this already.
Old 01-02-2008, 04:14 AM   #6 (permalink)
PSS
I meant to reply to 'edride' and busasandrail and Gene'. *Happy New Year!
Old 01-02-2008, 11:49 AM   #7 (permalink)
BANNED
There are severeal clutch slave supports on the market for the busa. Do a google for them.
Old 01-02-2008, 11:50 AM   #8 (permalink)
Nice stop Harv! Great solution. Just as nice as your rocket stuff. Happy New Year.
Desertkarts is offline   Reply With Quote
Old 01-02-2008, 11:58 AM   #9 (permalink)
BANNED
You may also want to dump the rubber bumper.It's gonna cause trouble.You need a positive stop to prevent more clutch headches. Just a stronger cover will not prevent overtravel issues and the resilient bumper will not give consistent travel.I guarentee you that in the "heat of the moment" you'll compress that bumper and overtravel the clutch slave cylinder. Doesn't take much.
Old 01-02-2008, 06:35 PM   #10 (permalink)
Thanks desertkarts and masterfabr, *I googled as you suggested and see there are lots of slave mount supports out there so I'll buy or make one. *I have the rubber/plastic stops in different hardnesses (shore). *They are actually polyurethane and range from a rubber like softness to a plastic like hardness. *The very hard urethane stops are very durable so I'll switch to one of those on my pedal stop setup.
