Old 11-01-2007, 12:17 AM   #1 (permalink)
Default crash switch disable
i know some if the brighter senior members have figured out how to use resistors-i couldnt get mine to work.so i pryed open the crash switch.found a little wheel with a magnet molded into the plastic at the bottem.this fit into bottem cover.i removed the wheel and plugged in the crash switch.it works fine-with no fear of the crash switch ever being tripped.looks like the switch has a hall effect sensor in the little circuit board inside.
fz1mini is offline   Reply With Quote
Old 11-01-2007, 01:00 AM   #2 (permalink)
BANNED
Default Re: crash switch disable
yep.
