Old 03-27-2007, 03:09 AM   #21 (permalink)
Default Re: Alternator???
You wont miss me i promise....
Old 03-27-2007, 03:12 AM   #22 (permalink)
dune's Avatar
Well can they run backwards or not?
dune is offline   Reply With Quote
Old 03-27-2007, 03:28 AM   #23 (permalink)
well a honda car one can, you got to get the one that runs funky oem tho....not sure what model or year but i know one of them does....
Old 03-27-2007, 03:39 AM   #24 (permalink)
Honda's J Series engine was designed in the US by Honda engineers and built at Honda's Anna, Ohio engine plant specifically to bolt up to GM's clockwise rotating transmissions, so any pre-J Series alternator should do the trick.
Old 03-27-2007, 03:44 AM   #25 (permalink)
dune's Avatar
looking at the way k-fabs was set up on the left side of the output shaft it appears his would have been running counterclockwise correct?
Old 03-27-2007, 11:59 AM   #26 (permalink)
BANNED
An alternator itself does not care if it runs clockwise or counter-clockwise.The threaded shaft will be LH/RH threads as appropriate from the OEM but so long as you have the nut positively retained with red loctite on CLEAN threads you won't have a problem with the "incorrect" handed threads coming loose.
Old 03-27-2007, 02:46 PM   #27 (permalink)
dune's Avatar
That's what I was hoping. Thanks
