just curious if anyone has used a rear caliper off of a bike and then used a master cylinder off a car?
reason i ask is i have a suzuki swift master cylinder and pedal assembly in the buggy and i want to use a motorcylce caliper.. you guys think this idea will work out for me? im thinkin ill just have to get a adapter to go fromt eh steel car line to the flex line of the caliper as it has the banjo fitting on it any thoughts? Trevor |
#4 (permalink) |
3/4" MC = 3/4" diameter cylinder Master Cylinder
1:6 ratio on the pedal would be 1" of pedal length on one side of the pivot bolt and 6" on the other side of it, or some ratio equivalent to that. |
#6 (permalink) |
Another question, but the same thing, not trying to hijack. What if I'm using 3 motorcycle calipers on one master cylinder? Maybe go to a larger master cylinder than 3/4? Thanks.
Edge Barracuda powered by a 2002 GSXR 750 engine with Fox air shocks and other goodies. It finally moves!
#7 (permalink) |
Lyinlow,
I used a Geo Master cylender in the Wife's buggy I don't know how great this one works, but have used car masters in the past with no problems... They tend to have a really tight pedal feel because they push a lot of fluid compared to the small amount that the smaller bugggy calipers take to be actuated...Hope this helps you out ...BTW the local auto parts store can hook you up with the fittings and hard line...There was a thread awhile ago on using plastic line but I can't tell you the name of the thread... ![]()
EVIL 6's LOOSE CANNON |
#8 (permalink) |
Calipers only displace a small amount of fluid when applied. The piston/pistons only move a few thousandths when applied.It's the *pedal ratio (pressure)that you're after.YOu should be ok with a 3/4" bore.
#9 (permalink) |
#10 (permalink) |
Master,
If you take the diameter of the car caliper and compare it to the bike caliper it takes alot more fluid to move the piston on the car caliper volume wise... I tried a stock pedal assembly once and a foot wiggle put you in the harness...
