Old 11-18-2006, 08:08 AM   #1 (permalink)
Default spark on 929 2001 fuel inj.
ok everything cks. out good went by the specks and still no spark also it does not have the chip in the key thingy or from i understand if it did there would be a pic of a key on the gauges and it would stay lit . so i do have a light on the instrument panel that stays on its at the bottom and is red any one got any ideas what it is or what i should do next to get spark to the plugs also the stop switch and starter switch were acting funny it was like i had them pledged in to each other the stop switch would act like it was the starter and the starter would act like the stop and also the fuel pump does not come on all the time it also acted like it was connected to the stop switch then all of a sudden the starter switch and stop switch acted normal but the fuel pump does not come on now ? and all threw this the red light still stays on checked it for errors and nothing came up rechecked the wires and plugs to make shore there ok and in the right place and they are. the kick stand is wired ok neutral switch also is ok. the lean sensor is ok I'm up for any ideas only thing I'm coming up with is the ecm board is fried *did i do anything to fry it ? no did it work when i got it ? i don't know also tried the diode on the pink wire and that didn't do it ether so gentlemen I'm up for any ideas and would really opreciate it
* * * * * * * * * * * * * thankyou *
* * * * * * * * * * * * * * * *driller
driller is offline   Reply With Quote
Old 11-18-2006, 01:41 PM   #2 (permalink)
Bugpac's Avatar
Default Re: spark on 929 2001 fuel inj.
is the key anti theft, i assume it is. that needs to be bypassed etc, also do you have a roll over sensor, i just went thru the same with mine, once i got the roll sensor positioned right it fired right up, but mine also gsxr...just food for thought, good luck .....
Old 11-18-2006, 04:51 PM   #3 (permalink)
lean sensor is in right direction if key was anti theft acording to hayes manuel it would have a picture of it in the insturment panel so i would have to say no gonna see if i can somehow check the ecm board today and also price one out thanks for the reply if ya got anymore ideas plz bring them on.
Old 12-05-2006, 04:34 AM   #4 (permalink)
Did you buy the manual yet? I know it sounds redundant but on my rc51 there are several plugs that are the same, plug 'em in to the wong item and it won't read correctly = no go. Disregard if you've been this route already, don't mean to step on any toes.
matchew is offline   Reply With Quote
