Old 09-07-2006, 03:08 AM   #1 (permalink)
Default Clutch Master Cylinder
Is anybody using a CNC master cylinder (or other brand) to actuate the stock clutch hydraulic slave on a motorcycle engine? The ZX14 motor I am using has a hydraulic clutch actuator and I am concerned that I won't get much throw on a standard master cylinder when hooked up to the motorcycle clutch. What are you guys using, and what size?
I could rig up the stock motorcycle master cylinder, but I don't think it would be the cleanest setup.
Thanks!
Baja Explorer is offline   Reply With Quote
Old 09-07-2006, 03:26 AM   #2 (permalink)
Send a message via Yahoo to AtvNut
if you have access to the original motorcycle one I would check its output then use that as a guideline for a replacement foot pedal type master
AtvNut is offline   Reply With Quote
Old 09-07-2006, 05:38 AM   #3 (permalink)
Hi Baja Explorer
There was a little info on people using a master cylinder for the clutch in this thread
http://www.minibuggy.net/viewtopic.php?t=310
Old 09-07-2006, 12:17 PM   #4 (permalink)
Administrator
K-fab's Avatar
Call Jay Largo at [url=http://www.desertdogoffroad.com:lazeb5mk]Desert Dog Off Road[/url:lazeb5mk] and ask him what size bore he's using.
He runs a Jamar pedal setup in his cars and operates a Busa's clutch with the pedal setup.
Old 09-07-2006, 12:48 PM   #5 (permalink)
ProtoDie's Avatar
I am using a 5/8 bore master cylinder with 1 1/2 stroke for my clutch. This is driving the slave cylinder, which is then hooked up to the stock bike clutch cable (GSXR 600)
My pedal is adjustable, but I have it set up with about 2 1/2 -3" of throw and the pedal is easy to engage.
My brother changed his up to a 7/8 bore master cylinder (maybe 1", not sure) and this shortened up the pedal stroke to maybe 1 1/2" and the pedal is alot stiffer to engage.
ProtoDie
Design without limits
www.protodie.com
ProtoDie is offline   Reply With Quote
Old 09-07-2006, 01:09 PM   #6 (permalink)
ProtoDie's Avatar
I also was not happy on how quickly the pedal returned. I added a assist spring to the slave cylinder to make sure it returned all the way, worked out nice.
Look to the frame just above the nerf bar plate
ProtoDie
www.protodie.com
Old 09-07-2006, 01:20 PM   #7 (permalink)
ProtoDie's Avatar
I started with this pedal set from desert carts http://www.desertkarts.com/item80911.ctlg
I ended up just using the cylinders and 1 of the pedals to make my own pedal setup. I wanted a wide brake pedal to be able to brake with either foot, and my steering shaft is right in the center.
ProtoDie
www.protodie.com
Old 09-08-2006, 05:46 AM   #8 (permalink)
I am using the entry level Jamar clutch / brake master cylinder assembly and the clutch master has more than enough volume, as a matter of fact too much, I broke the slave cylinder case when my foot slipped and the clutch pedal made full travel, you will have to limit the master cylinder pedal travel.
After 2 years of using the Jamar pedal assembly I am ready to change to another brand, maybe CNC. I say this for the following reasons. First, there is so much vibration in the chassis that the fluid vibrates out of the master cylinder, maybe a different type cover will solve that problem. Second the pivot/pushrod retaining bolt is exactly that, a bolt and I have had it vibrate loose twice, even using blue thread locker. CNC uses a collered pin with a cotter pin to retain the pin, maybe I will just drill the pedal assmblies and use the CNC pins. JUst my 2 cents worth.
Glamisman is offline   Reply With Quote
