#21 (permalink) |
I would say, holding the switch strait up and down, measure the resistance between the center wire and the "brownish" lower wire. The put a resistor of the same value between the two and call it good.
#23 (permalink) | |
#24 (permalink) |
I messed up the 03 at Bob's a couple of weeks ago. In the mud fest,,,,,, [smilie=big_explode.gif]
Should have never ran in that slop. 10 hours of cleaning on the car, my radiator is leaking from all the gravel/mud that got packed in it in 4 laps . We never even got over 8 miles an hour, could not steer or hardly go. Throttle started sticking, as did the shift linkage from the mud. When I got back from the power wash and cleaned up the car the rest of the way,,,,,I noticed water in the oil. Not sure if it was from the powerwash or if I went thru a head gasket or something. Changed oil 4 times, but may have a little water in it yet,,,,,,,,so not sure if the head gasket it bad or not. Motor runs fine, but compression seems low. So I picked up an 04 to put in it. Dan's 04 has larger throttle bodies and seems to have more/ smoother power. So I went to an 04 to race him apples to apples. I have the whole motor (03) kit and harness as a back up, and plan on checking out the problem later. Just wanted to get the buggy running and race ready,,,,,quickly. I should be done with the change over tomorrow, waiting on my radiator from hyper. I also plan on getting the leaking radiator repaired. * * It was a very expensive 4 laps of mud. |
