Old 12-23-2005, 04:11 PM   #1 (permalink)
Default Steering Shaft Mount
I'm compiling parts for my first mini-rail project and I'm trying figure out how I'm going to mount the steering shaft to the chassis. I like the billet mounts but the only manufacturer I've found that makes one for 1 1/4" tubing is Gear One. Are there any other manufacturer's? Or are there any other type of mounts that function good and also look good?
blackbird is offline   Reply With Quote
Old 12-23-2005, 09:23 PM   #2 (permalink)
Admin
Gene's Avatar
Default Steering mount
Maybe some of the other guys know of alternates. What are you mounting it to (frame type)?
Old 12-24-2005, 04:16 AM   #3 (permalink)
diirk's Avatar
[url=http://kregerfab.com/othrprod.htm:230mlsko]Here's[/url:230mlsko] one. Welds on and provides a tilt wheel. I believe the notch at the top can be made to the size you need.
Or, you can just make a sleeve for the cross tube to increase the diameter to 1.5".
diirk is offline   Reply With Quote
Old 12-24-2005, 05:04 AM   #4 (permalink)
Default Re: Steering mount
My frame will be a custom design that I'm trying to finishing up at the moment on AutoCAD. I was hoping to be done designing by now but I keep on changing things! :roll:
Old 12-25-2005, 09:47 PM   #5 (permalink)
I run the Gear-One billet steering shaft on my mini. It fits great unlike a lot of the other cheaper models and they are the only ones that make one for 1.25". I would definately spend the money on it again if I built another car.
f1prerun is offline   Reply With Quote
