Results 1 to 10 of 17
    UPRIGHT DESIGN- HELP NEED MORE STEERING ANGLE
    Senior Member nofearmxer's Avatar
    Aug 2009
    Manhattan, KS
    I designed an built my first set of uprights.
    I used an online suspension geometry calculator to locate my steering arms on the uprights to minimize bump steer.
    Problem is I now dont have enough steering angle
    Any suggestions??
    Let me know if you need any other info.
    I have everything in SW, I just dont have a picture of the assembly on this computer right now.
    THANKS Guys
    Mitch
    (I hope these pictures show up)
    Re: UPRIGHT DESIGN- HELP NEED MORE STEERING ANGLE
    Aug 2009
    Manhattan, KS
    It ok cause the steering arms need to be redone anyhow.
    Anybody???
    Right now you have reverse ackerman. Like real bad. You need to move the pivots on the rack out so that you can move the arm pivots out. That and maybe some shorter arm's? they look real long, but with where the rack pivots are currently you probably would have run into clearance issues making them any shorter.
    It's all a game of compromises................
    Aug 2009
    Manhattan, KS
    Thanks guys,
    I got it all squared away now.
    Senior Member deaner's Avatar
    Sep 2011
    Northern Ohio
    Post some pics so we can see how it turned out.
    ^^^^This. That inside tire cant turn much at all.
    May 2013
    Easton, PA
    swap the steering arms side to side and, flip the box and move it inside. bye bye reverse ack.
    Quote Originally Posted by Xbird View Post
    This would prob work, and changing rack mount so steer shaft don't hit that cross tube of chassis. Angle up a bit to lessen the u-joint angle.
  1. New Design Hydraulic Power Steering Rack
    By whitedragon64 in forum Controls and electrical
    Last Post: 07-03-2016, 08:56 AM
  2. Steering system design doubt
    By kaushalful in forum Controls and electrical
    Last Post: 07-07-2012, 10:21 AM
  3. Steering system design doubt
    By kaushalful in forum SAE Baja
    Last Post: 07-07-2012, 04:40 AM
  4. Spindle steering arm wrong angle (w/pic)
    By Travitanium in forum Suspension - Wheels & Tires
    Last Post: 11-06-2010, 10:39 AM
  5. Steering angle for turning
    By TEO in forum Suspension - Wheels & Tires
    Last Post: 12-10-2009, 01:47 PM
