Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
    Re: Proper wiring for a rotax 503 (Ski doo I think)
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    Gravity should work you might have a fuel pump that look like this.
    The size of the fuel line probably won't be the determining factor. The float valve has a lot to do with it.
    I took a Mikuni carburetor off an engine that used a pulse pump and put it on an ATV that was gravity fed. It would run fine until I cracked the throttle wide open. After a few moments, it would be starving for fuel. Conversely, I took a Mikuni carburetor off an engine using a gravity feed and put it on an engine that had a pulse pump. I started having issues with flooding.
    I learned that the Mikuni carburetors have different apertures on the float valve, depending on the application. The carburetor that was used with a pulse pump had a 1.5 aperture, while the carburetor that was gravity fed had a 2.5 aperture. When I ordered and installed the correct float valve for each fuel setup, all my issues went away.
    Something to check while you're working on your engine.
  1. Proper 4 seat mini
    By Reflex in forum MiniBuggy.net Lounge!
    Last Post: 06-22-2012, 10:43 AM
  2. A Proper Introduction
    By NoClue in forum The Welcome Mat
    Last Post: 06-01-2012, 11:28 AM
  3. Proper grounding?
    By maconbass in forum Controls and electrical
    Last Post: 03-07-2011, 06:05 PM
  4. Proper electric ground routing
    By bajaBrothers in forum Controls and electrical
    Last Post: 12-10-2007, 01:05 PM
  5. Proper jumping technique
    By masterfabr in forum Driveline
    Last Post: 05-30-2007, 10:56 PM
