Old 11-15-2009, 07:57 PM   #1 (permalink)
nofearmxer's Avatar
Default Drakart 583 wiring diagram
Any body have any info on a rotax 583 wiring diagram. Google turned up nothing for me.
I need to check my magneto, lighting coil, ect.. on a 583 Drakart
nofearmxer is offline   Reply With Quote
Old 11-15-2009, 09:54 PM   #2 (permalink)
XRH348's Avatar
Default Re: Drakart 583 wiring diagram
I looked on the web for the engine related wiring diagram for the skidoo it came from, and in the "Snowmobile Forum" webpage
94 formula z - Snowmobile Forum: Your #1 Snowmobile Forum
there was this :--
Get a Clymer's manual for it too. That's the manual I have, it has wiring diagrams in the back. There is a method for timing the rotary valve, I can post it if you want, but that Clymer manual is your bible for that sled.
hope this helps
Also try googling "images" for Rotax wiring diagrams you could get something there
XRH348 is offline   Reply With Quote
Old 11-15-2009, 10:18 PM   #3 (permalink)
nofearmxer's Avatar
yea I had already seen that and it does me no help..........thanks tho. I already tried and google like I had said did not help. Bing wont either.
I was hoping somebody with one of these dreadful Drakarts had some info since these are such a pain in the ass.
I cant get a manual or Clymer book because I dont know what the hell it is. Its a pieced together piece of shit. A 19?? 582 bottom end with a 19?? 583 top end. Thats all I know and all I have figured out after hours on the phone and hundreds of hours on a damn computer. So far DRAKART SUCKS NOBODY BUY A DRAKART>>>>>>>>>EVER!!!!!!!! Unless you built it and know what you have.
Thanks
Old 11-16-2009, 03:52 PM   #4 (permalink)
Send a message via Yahoo to AtvNut
What is wrong with the engine? How does it run that makes you think you need a wiring diagram?
AtvNut is offline   Reply With Quote
Old 11-16-2009, 05:31 PM   #5 (permalink)
nofearmxer's Avatar
I have electrical issues so I need to find out what wires I need to check and see what they are supposed to put out. The stator/coils are not recharging the battery. So I turn on my lights and after 3 min they dim and my battery is completly dead.
Old 11-16-2009, 06:29 PM   #6 (permalink)
I will amend this later but your voltage regulator should have three wires. A yellow black and a yellow, along with a red one. the yellow wires are 12v AC if I recall correctly I will be back later and add anything else that comes to mind.
Old 11-16-2009, 06:44 PM   #7 (permalink)
nofearmxer's Avatar
I have 2 yellows going to a two wire plug and a 3 wire plug that has a red, red/black, and red. Thats what I have comming out of the lighting coil assembaly, its round with 12 coils on it. I dont know how many ohms there is supposed to be since I have no idea what year/model this sled engine is out of on this Drakart. All i know is that the Drakarts is a 2000 583...kind of...582 bottom end.
Old 11-16-2009, 09:38 PM   #8 (permalink)
Hi there, iff you are running a 583 from a ski doo
you can get the shop manual at this site (chadt.us-snowmobikemanuals)
I got the 1997 manual and its the same as the 1994 engine i am using
good luck
ps all the measurements for coil and the rest of the electrics are there
locost is online now   Reply With Quote
Old 11-16-2009, 09:52 PM   #9 (permalink)
if the regulator does not have a red wire it will not charge the battery, They have the same plug just less one wire..
Old 11-16-2009, 09:56 PM   #10 (permalink)
http://www.dootalk.com/forums/index....post&id=148256
wiring diagram lacydawn27 The Pilot & Odyssey Forum 2 10-30-2009 03:29 AM
02 Drakart 600cc wiring diagram bazz Controls and electrical 3 10-18-2008 11:26 AM
gsxr 1000 wiring diagram SeufererMotorsports Controls and electrical 4 06-09-2008 11:54 PM
yamaha enticer 340cc wiring diagram glyn Motor - Engine 0 05-25-2008 08:35 PM
CBR 600F4 wiring diagram???? flyerrider Controls and electrical 15 12-15-2006 05:53 PM
