Old 11-06-2009, 03:47 AM   #1 (permalink)
Default Busa fuse box
When you modify your harness or have it modified is the stock fuse box with the side stand relay still there?
Glamisman is offline   Reply With Quote
Old 11-06-2009, 04:53 AM   #2 (permalink)
Admin
Gene's Avatar
Default Re: Busa fuse box
My modified harness on both cars dumps the stock fuse box. A new fuse panel is used with relays to switches.
Old 11-06-2009, 05:28 AM   #3 (permalink)
busasandrail's Avatar
You can leave the stock and run your power through it but using an aftermarket unit will give you a better finished product plus allows you to have more circuits and better protection.
Old 11-06-2009, 12:54 PM   #4 (permalink)
yoshi's Avatar
I run both, leaving the stock fuse for the fuel pump and a couple others, I then add my own for all my accessories........
The top pic is a little earlier wiring, the second pic is cleaner and the way I run them now, but the top one is to show a close up of the fuse post I run
www.sinistersandsports.com
$16,000 Busa car looking for a redline revolt Quadrockets For Sale 12 11-08-2009 03:19 AM
Busa motor in car...just running...a few questions turbomatt Motor - Engine 1 08-12-2009 05:09 AM
R1 vs. Busa Andy_1972 Motor - Engine 78 03-23-2008 10:58 PM
hayabusa wiring? edride Controls and electrical 9 09-20-2007 09:17 PM
Blowing the main 30amp fuse on the Busa-Buggy DuneMe Controls and electrical 8 04-02-2007 02:56 PM
