#14 (permalink) |
If you look at number 3 and 4 in your diargam the throttle switch and the TORS are connected so if the CDI is not seeing what it needs to from them it might not spark.
The initial spark is as it gets spinng then realizes the engineers conditions are not being met. Does it spark just once? Or two or three times? For now I would check EVERY wire in and out of the CDI for its proper signal. If the signals are correct the CDI may be bad.
#16 (permalink) |
Pretty sure it ran, not positive.
Just one spark,nice fat blue one. Thanks for your help BTW. I'll do all your suggestions when i get home. BTW,the last guy parted it out because it wouldnt start,but i found the wire that he pinched/broke.
People who think they know everything,are especially annoying to those of us who do. |
#17 (permalink) |
3&4 just go to ground?I did that.
Nutz do you think that TORS indicator light could be doing something,i have the wires connected but no bulb.
#18 (permalink) | ||
I beleieve its a common pulse coil. See the coil feeds both plugs. Quote:
The "Engine stop switch" To kill the motor either one (main or engine stop) simply grounds out the signal and kills the spark. You say NO key switch and NO handle bar switch. WHAT did you do with those wires??
#20 (permalink) |
Not sure you want to see what i did to the harness.
Didnt have time to mess with it today ,and going riding tomorrow,but i'll try to get to it tommorrow.
| 1994 MachZ 780 Triple Sled for sale. | nutz4sand | For Sale | 9 | 11-16-2008 11:25 PM |
| sled and bike setup weight?? | Jos_19 | Driveline | 5 | 11-12-2008 11:01 PM |
| Need pics of a sled motor setup! | dune | Motor - Engine | 4 | 11-11-2008 08:09 PM |
| sled motor swap research | hansshanks | Motor - Engine | 59 | 04-04-2008 02:59 AM |
| SLED POWER 101 | renegadespec1 | Motor - Engine | 26 | 06-18-2007 01:23 PM |
