Old 11-01-2009, 11:06 PM   #11 (permalink)
Default Re: R1 Wiring Help
"RTVed the TIP sensor."
Can you give a few details? this is one of my last issues to address in my FZ1 wiring mess.
Dezzrats is offline   Reply With Quote
Old 11-02-2009, 05:53 PM   #12 (permalink)
Took it apart and used RTV Silicone Gasket Maker to permanently keep the tip sensor in the right place. You just have to be sure its right where it needs to be. I believe you can put a resistor in in its place, as an alternative.
Wild Earp is offline   Reply With Quote
Old 11-02-2009, 10:18 PM   #13 (permalink)
Administrator
K-fab's Avatar
My guess is that it's in the line that goes directly to the ECU. Doesn't make sense for it to go anywhere else.
I seem to sort of recall using a resistor somewhere when I did the harness, but where and what? No clue.
Old 11-02-2009, 10:21 PM   #14 (permalink)
I talked to Rosson Racing who does R1s for sprint cars, and he said no resisitor needed for the ignition switch. Hopefully hes correct.
Thanks for everybodys help, hopefully I get this thing right the first time, and it fires off.
Old 11-03-2009, 02:12 PM   #15 (permalink)
Thanks, I will open it up and take a look.
Kawasaki ZX14 Wiring / Sensor Bypassing standfast Controls and electrical 2 09-18-2009 03:46 PM
ZX10R Help. malibu vlx Controls and electrical 3 05-12-2009 06:30 PM
yamaha enticer 340cc wiring diagram glyn Motor - Engine 0 05-25-2008 09:35 PM
1988 gsxr1100 wiring dek3211 Motor - Engine 9 11-20-2007 10:15 PM
2004 zx 10 wiring manual enroffroad Controls and electrical 2 07-01-2007 05:25 AM
