Old 10-26-2009, 12:30 AM   #1 (permalink)
Default Front or rear steer
Wich would u choose and what are the advantages of each.
drognlin is offline   Reply With Quote
Old 10-26-2009, 12:40 AM   #2 (permalink)
Default Re: Front or rear steer
front is stronger. puts the tie rods in tension instead of compression...
Old 10-26-2009, 04:58 AM   #3 (permalink)
bdkw1's Avatar
What he said ^^^^^^^
About the only time rear steer makes since is on a small single seater for the kids where you just have a tab coming of the steering column for the tie rods which go under the legs.
Old 10-26-2009, 05:03 AM   #4 (permalink)
I go for rear steer, but not for any technical advantage. I just have a tendency to hit things, so if they're further to aft, less of a chance of tweaking them. Probably not the best reasoning, but at least I'm honest!
kevin quesenberry is offline   Reply With Quote
Old 10-26-2009, 11:53 AM   #5 (permalink)
Administrator
K-fab's Avatar
I understand what you're saying, but you'll bend the tie rods (probably more often) when you hit things with the front wheels too. Go front steer. Otherwise you'll be constantly chasing broken/bent parts.
Old 10-26-2009, 01:51 PM   #6 (permalink)
Super Moderator
minibajaman's Avatar
I have rear steer due to packaging constraints in a small single seat buggy. I don't hit things too often but I have yet to bend a tie rod in 3 years and they are only 5/8 x .065 tubing.
I agree that front steer is stronger, but IMO it really depends on your buggy design and what fits best. You can always make stronger tie rods if they have problems bending.
Old 10-26-2009, 05:59 PM   #7 (permalink)
Good to hear that .065 wall is holding up. My tie rods are 3/4 od x.065 wall on the new double a with front steer. I was thinking about going heavier, but now I'll just leave it alone. If you hit something they're gonna bend regardless.
RickS. is offline   Reply With Quote
Old 10-26-2009, 06:30 PM   #8 (permalink)
Rear steer is easier to get a reasonable amount of ackerman. It also protects the tie rods more. I think it would be quite hard to buckle a reasonable size tie rod from compression, without hitting it first. But just because its never happened to me doesnt mean it cant.
Damien is offline   Reply With Quote
Old 10-26-2009, 06:46 PM   #9 (permalink)
nutz4sand's Avatar
For the size of them spare tie rods could be hauled ON the buggy IF you bent a rear steer one. If your building anyway how hard is it to make a spare tie rod?
I see a lot of people who go with front just to make foot room.
Sand! The only gold I need!
Old 10-26-2009, 08:33 PM   #10 (permalink)
I am hoping to go front steer but a little comcerned about room in the spindle area to get true ackerman
Racing Cost & Information for each Class. TutTech MiniBuggy.net Lounge! 4 10-13-2009 04:13 PM
Front Track Width vs. Rear track width ratio. . .for turning radius??? atomicjoe23 Suspension - Wheels & Tires 3 06-30-2009 06:48 PM
Cut & replaced the front end of my brothers 9 car. Finished TutTech Projects in Progress 9 04-13-2009 03:00 PM
front and rear susp ptrfiat Suspension - Wheels & Tires 7 02-26-2009 05:32 PM
Why front steer not rear steer? billium Suspension - Wheels & Tires 10 01-20-2006 07:05 PM
