Old 10-08-2009, 03:44 AM   #1 (permalink)
Default Arm restraint question
Not sure if this is the discussion board for this question but at any rate, is there a specific spot the arm restraints are suppose to mount at? Do they loop into the seat belt or do you weld on a ring or something near the steering column for them to hook on to?
Thanks!
Andy
andy777bmx is offline   Reply With Quote
Old 10-08-2009, 03:46 AM   #2 (permalink)
Default Re: Arm restraint question
Most hook the seat belt so when you un buckle in a hurry they come free...
Old 10-08-2009, 02:10 PM   #3 (permalink)
Administrator
K-fab's Avatar
DO NOT attach any sort of arm restraint to the chassis - you want the restraints to come out of the car with you.
Most of the time the arm restraints have a loop that you run the seat belt tab through before securing the belt. This way, when you release the belt, it lets the arm restraints come free from the car, but stay with your arms.
Don't run the restraints down the belts - make sure you keep where they attach as close to the buckle as possible.
Old 10-08-2009, 02:28 PM   #4 (permalink)
I always hook mine on the sub strap. so they cant come up...
Old 10-08-2009, 02:33 PM   #5 (permalink)
yummi's Avatar
Assuming you have a crotch strap use the loop on that strap so it is below the buckle assembly - that way in the event of a roll, it pulls against a "limit" that is imposed on it by the lap belt. It also may have less in the way of buckles, etc to catch on in the event of a quick exit.
I like things that move.
Pretty much limits me to cars and strippers
yummi is offline   Reply With Quote
Old 10-08-2009, 03:14 PM   #6 (permalink)
yoshi's Avatar
I run them on each corner of the bed, although I need to run 4 for the bottom post because my wife has really strong legs and keeps breaking them.....
www.sinistersandsports.com
Old 10-08-2009, 03:46 PM   #7 (permalink)
LiveWire's Avatar
I'm having a hard time visualizing. Can you post pics?
Old 10-08-2009, 04:10 PM   #8 (permalink)
yoshi's Avatar
I would but she broke the camera again, I really need to mount it farther away next time.....
Old 10-08-2009, 09:48 PM   #9 (permalink)
Haha, thats funny stuff . I'm about to tear down my build and paint and do some last minute things. I'll be sure to post some pictures when done. This was my first build and a learning experience but i think it turned out decent considering.
Old 10-09-2009, 07:59 PM   #10 (permalink)
jumpin jellybean's Avatar
Yoshi just get the swing that hangs from ceiling, you only need one attachment point, just put it in double shear schould be fine thanks for the laugh
Shock location question andy777bmx Suspension - Wheels & Tires 4 04-14-2009 08:58 PM
Quick question about trailing arms andy777bmx Suspension - Wheels & Tires 10 01-23-2009 02:32 AM
Trailing arm question wastintime Suspension - Wheels & Tires 11 11-24-2008 05:17 AM
A general frame question: CrimsonBugger Frame 16 10-09-2008 12:15 AM
cv question Stomper Driveline 32 07-17-2008 11:38 PM
