Old 09-30-2009, 01:36 PM   #1 (permalink)
Con
Default zzr1100D Spark problems
Hi all , great forum ye have here
Im currently building an edge piranha buggy powered by a zzr1100 96 motor
i have the engine and all of the loom wired in, the engine is turning over , BUT im not getting any spark at the plugs,
Do the ignition coils have to be grounded to the frame to get a decent spark? also i have wired in the clutch neutral and sidestand switch, any feedback would be much appreciated
also would a ground from the neg terminal of the battery to the frame appropriate?, the engine is grounded anyway
Cheers
Con
Con is offline   Reply With Quote
Old 10-02-2009, 02:24 PM   #2 (permalink)
Administrator
K-fab's Avatar
Default Re: zzr1100D Spark problems
Battery to frame and engine to frame should be sufficient - just make sure you use a proper sized wire and that there is no paint or any sort of insulating garbage (rust, oil, paint, etc.) anywhere near the connections to the frame.
Does the bike have a coded key? That may be an issue. There are anti-theft setups in a lot of the newer bikes and you may have an issue there.
kick stand, neutral switch, tip over sensor, clutch switch, oil level check switch, handle bar run/stop switch - all of those should be checked again to see if they are either bypassed or working correctly.
Old 10-05-2009, 01:59 PM   #3 (permalink)
Con
Thanks for the reply, ya re checked all that but seems ok again i will check the earths, found a broken earth near the clocks,, its a 96 zzr1100,, also may have a problem with the coils, going to check them this eve.. must post some pics soon, long term project, cant wait to get her running..
Cheers
PS some of them yellow dog Lites are pretty sweet
won't start, no spark fl250 lost The Pilot & Odyssey Forum 6 02-27-2009 05:57 PM
cbr 600 f4 motor no spark :( jkarner Motor - Engine 9 01-12-2009 02:14 AM
honda odyssey with no spark fl250dirtslinger The Pilot & Odyssey Forum 20 10-29-2008 02:18 AM
01'Cbr929rr. No spark or fuel. PLEASE HELP! cbr929_build_up Motor - Engine 20 09-20-2007 06:01 AM
spark arrestor hotwheels000 Motor - Engine 12 03-09-2006 04:08 PM
