Old 06-11-2009, 01:13 AM   #1 (permalink)
Default Kawasaki KL650 Gauges
Howdy folks,
I recently purchased a partially done home-made mini rail. I would like to get a tach, speedo, oil pressure, volts, and water temp gauge. I just don't have a clue where to start. I am not familiar with bike motors, and I have never built a buggy. Could you guys give me some direction. Sorry if this topic has been covered...
Thanks
-Jay
JaySea20 is offline   Reply With Quote
Old 06-11-2009, 02:46 AM   #2 (permalink)
bdkw1's Avatar
Default Re: Kawasaki KL650 Gauges
Easy ones are volts, water temp and oil pressure. Run aftermarket gages and sending units. Tach isn't very useful while driving. Speedo is going to be difficult.
BTW, your motor is more than likely a KLR650.
Old 06-11-2009, 04:09 AM   #3 (permalink)
Admin
Gene's Avatar
Welcome to MBN!
What is the engine, does it run, do you have the orignina gauge cluster?
Some things aren't worth watching or aren't watchable at speed.
Old 06-11-2009, 02:11 PM   #4 (permalink)
Thanks for the responses guys. The numbers on the block are KL650AE..... The motor probably came off of a klr650. Yes, the motor runs quite good after cleaning the idle jet and capping the open line on the motor side of the carb. It has a high flow muffler though, and im pretty sure it is the stock jet. So, it runs a little lean on the top end.
Anyway, back to the topic. I have the original gauge cluster. and the original harness. But the harness is a hacked mess, and the gauges do not work.
-Jay
Old 06-11-2009, 08:17 PM   #5 (permalink)
diirk's Avatar
A bike computer will work for a speedo. Or, if you want to get fancy, a Trailtech will do the job nicely too.
Bike Computer $15:
Trailtech $50-$125:
diirk is offline   Reply With Quote
Old 06-12-2009, 06:04 AM   #6 (permalink)
Thanks Diirk,
Those things are cool. Is that GPS?
I have my heart set on anolog gauges. The good news is that I got my tach and temp working today. My speedometer takes some kind of mechanical cable though.
On another subject, anyone know where the "fan" temp switch is located on my KL650?
After seven hours of re-wiring, I was able to correct most of the problems. But, my speedo and fan do not work properly yet. I am more worried about the fan switch or the temp sensor than I am the speedo.
Still, any help is AWESOME!!!
-Jay
Old 06-12-2009, 02:47 PM   #7 (permalink)
diirk's Avatar
Neither of those are GPS, but that's another option for speedo. Mount a small gps and it will give you accurate speed info. I hear you on analog guages. I've always been a fan, but I think this time I'm going digital...
Kawasaki ZX14 Wiring / Sensor Bypassing standfast Controls and electrical 2 09-18-2009 02:46 PM
Trade: CLEAN 2004 Kawasaki KFX700 ATV jeemann99 For Sale 0 09-24-2008 02:45 PM
Hand built Kawasaki 2 stroke radial engine opsled MiniBuggy.net Lounge! 1 06-16-2008 01:15 AM
Kawasaki ZX 7R bikerdog Motor - Engine 4 12-02-2007 11:41 PM
Any opinions on the Kawasaki ZX14 engine FRANCO Motor - Engine 6 03-19-2007 08:27 PM
