Old 06-03-2009, 04:19 AM   #1 (permalink)
Unhappy no spark need help
Hi all I am working on an old honda fourtrax turned it into a buggy built a roll cage and put in a dash I rewired it and some how have no spark ignition turns over neutral light is on .I think the kill switch got messed up in the wireing is there a way to jump it out .\please help
\millwright
millwright is offline   Reply With Quote
Old 06-03-2009, 02:26 PM   #2 (permalink)
Administrator
K-fab's Avatar
Default Re: no spark need help
Kill switches go to ground - so when you push the button, it grounds out the system and send the signal that usually goes to the coil back to the frame. (path of least resistance)
The easiest way to see if you've managed to screw up the kill switch is to unplug it from the wire harness and then see if the machine has spark. If it does, then you know the switch is the culprit. - and make sure that you can quickly attach the switch once the machine starts (it should die if the switch is the issue).
Old 06-04-2009, 12:53 AM   #3 (permalink)
Thanks K Fab problem is dont no which wire is for kill switch.
Old 06-04-2009, 03:19 AM   #4 (permalink)
Administrator
K-fab's Avatar
LOL!! A bit of a predicament, eh?
What are the colors of the wires you're dealing with?
Black w/white stripe (may be red) usually goes to the switch and then a green wire will run from the switch to ground.
cbr 600 f4 motor no spark :( jkarner Motor - Engine 9 01-12-2009 02:14 AM
honda odyssey with no spark fl250dirtslinger The Pilot & Odyssey Forum 20 10-29-2008 02:18 AM
01'Cbr929rr. No spark or fuel. PLEASE HELP! cbr929_build_up Motor - Engine 20 09-20-2007 06:01 AM
spark on 929 2001 fuel inj. driller Controls and electrical 3 12-05-2006 04:34 AM
spark arrestor hotwheels000 Motor - Engine 12 03-09-2006 04:08 PM
