ok. try to keep it simple.
Running cnc brakes 3/4' master cylinder with their slave cylinder on a 2005 r1. With about 3-4" of pedal movement i only get about 7/16" throw at the slave which is not enough to engage the clutch. If i remove my floorboard i am able to get the full swing out of the pedal which is probably closer to 8". At this point the slave pulls about 1" and the clutch will engage properly. How can i make it so the slave cylinder pulls 1" but the pedal only requires 3-4" of travel? Larger master? Everyone keeps saying even the 3/4" will overthrow the clutch (w/o a stop), and i need smaller master but i am having the exact oposite problem. I have moved the pivit point on the engines clutch arm so it is about 1/8" closer to the centerline, i have preloaded the arm approx 1/4" and i have the pedal as high as the clevis will allow. I'm pretty certain we do not have any airbubbles in the system, but it just seems like nothing happens for the first half of the pedal stroke, then the second half it pulls the full range at the slave cylinder. any help would be greatly appreciated. |
#4 (permalink) |
I used about 1" of pedal throw on my R1 clutch with cnc pedals. Just be careful you dont move it too much or it will pull the geared shaft out of the clutch and you will need to tear the clutch apart to fix. Not hard just a pain in the butt to do. You may have already done this and its why the clutch wont disengage. the shaft moves but the shaft has been pulled past the gears it meshes with and now it will not pull the clutch plates apart.
#5 (permalink) |
Binch bleed? Never heard of this.
#6 (permalink) |
Think he meant BENCH bleed. You need to re-circulate the fluid in a fresh master cylinder to get all of the air out of the piston assembly. You do this by running a tube from the fitting, that goes to the brakes, back into the reservoir. Fill the reservoir with fluid and pump the piston until all air has escaped.
#7 (permalink) |
I don't think anyone asked, but what size of slave cylinder are you using? It looks big from the pictures.
#9 (permalink) |
I used the same slave on my r1 as you did and it worked fine. Check to see if you can get the clutch to disengage at all with the slave. If so you and you just need more pedal throw you can adjust the clevis on the pedal that pushes the pedal out from the mc giving you more travel before the floor. You can also clock the clutch arm on the trans to help a little.
| Busa motor flywheel. | masterfabr | Driveline | 44 | 06-15-2009 06:31 PM |
| Driven CVT Clutch to Gearbox Mating | SCBaja | Driveline | 18 | 11-11-2008 12:25 AM |
| Clutch Removal on FL400? | flyerrider | The Pilot & Odyssey Forum | 11 | 04-11-2008 01:00 PM |
| Hand clutch Ideas... | whiplash | Controls and electrical | 14 | 02-12-2008 02:53 PM |
| m/c hydro clutch to pedal hydro clutch ????? | bajaBrothers | Controls and electrical | 11 | 06-18-2007 05:28 PM |
