Old 12-16-2008, 01:18 AM   #1 (permalink)
Default Steering stops?
robndeb is offline   Reply With Quote
Old 12-16-2008, 01:37 AM   #2 (permalink)
Default Re: Steering stops?
Originally Posted by robndeb View Post
Our buggy has a nagging steering issue, when you turn all the way one way or the other, the outer wheel turns so much that the spindle steering arm makes contact with the suspension. It seems that the rack is a few inches forward of the spindles, making the tie rods angle rearward as they go out toward the spindle. This makes the outer wheel's steering arm over extend and almost lock up. Has anyone had this problem? If so, did you make some sort of steering stop? Aside from longer steering arms on the spindle, or moving the rack a couple of inches rearward, I don't know what to do. Help me out guys.
See what I mean.....
Turned all the way.......
got a downward picture of the rack and both front tires?
Old 12-16-2008, 01:42 AM   #3 (permalink)
SSC explains most of your problem. Anyhow you probably could make a rack adapter and loose some of the steering throw, I doubt the bumpsteer is accurate anyhow...How far is the opposing wheel turned when this picture is taken?
Old 12-16-2008, 01:43 AM   #4 (permalink)
Old 12-16-2008, 01:45 AM   #5 (permalink)
A few more pics, see what I mean, PLOW!
Pull the boots back on the rack, you will see a lock nut on the heim joint, put a big washer on there so the heim cant go into the rack body, you should at least be able to keep it from locking up and hitting and loose some steering degree, if you can undo the boot on one side and take a picture with it turned like that so we can see under the boot, on both sides would be best...the boot is zip tied on correct?
Old 12-16-2008, 02:07 AM   #6 (permalink)
[quote=Bugpac;153741]Pull the boots back on the rack, you will see a lock nut on the heim joint, put a big washer on there so the heim cant go into the rack body, you should at least be able to keep it from locking up and hitting and loose some steering degree, if you can undo the boot on one side and take a picture with it turned like that so we can see under the boot, on both sides would be best...the boot is zip tied on correct?[/QUOTE----------
Old 12-16-2008, 02:17 AM   #7 (permalink)
Old 12-16-2008, 02:44 AM   #8 (permalink)
The inner wheel is fine at full lock.....
Compared to the outer tire..........Yikes!!
Since it is a SSC, what other problems will I be expecting? Tell me, tell me!
the washers may limit travel to much, but will keep you from getting hurt anyhow till a real fix can be done...
Old 12-16-2008, 03:16 AM   #9 (permalink)
Old 12-16-2008, 04:08 AM   #10 (permalink)
Super Moderator
minibajaman's Avatar
I would first see if you can put some sort of spacer or stop on the rack itself to limit the amount of steering angle. If that doesn't work, you could make some sort of steering stop that welds on to the front uprights and contacts the a-arm to at least prevent the wheel from hitting the arm.
As you pointed out, there appears to be a ton of reverse Ackerman in that steering setup. You may want to consider remounting the rack to fix it at some point.
utv power steering Damien The UTV Area 73 12-18-2008 06:00 PM
Suspension scaling and steering Geometry Mike Suspension - Wheels & Tires 0 03-26-2008 11:49 PM
home made build 50nuts Projects in Progress 56 03-25-2008 11:31 PM
Power Steering.... Any one done it MrDiesel Controls and electrical 115 02-08-2008 07:45 PM
Sabretooth2 steering locking Phil Suspension - Wheels & Tires 3 07-07-2005 12:13 PM
